Buy a new timer. Any attempt at moving the pointer will likely strip the nylon gear. All it takes is 1 tooth on any of the gears being stripped to cause what you have described.
15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
