Hello. I am in need of some help. Our pool continues to go green and gross constantly. We have had the water tested and Chlorine was at 4 ppm which is right at range. The TA is high at 140 ppm...ouch! PH is 7.2, cyanuric acid is 99 ppm, phospahates 400 ppb..ouch, total dissolved solids is 1700. There is no iron or copper. I am so confused as to what to do. We can add alot of shock and then everything looks great but it is not helping the underlying issue and it is 110 degrees out and we aren't able to use our pool. The pool store had us but some phosphate stuff to put in it to clear things up. We use liquid chlorine, tablets in the basket, sodium ash or baking soda if the ph falls below 7.2. We are such green horns to this pool stuff and would really like some help. I appreciate your time and thanks.
~Rebekah
