Thread: Trichlor = How much CYA?
    Default Trichlor = How much CYA?
    I know I've seen it here before, but I could not find it--- so how much CYA does Trichlor tablets add to pool?
    Default Re: Trichlor = How much CYA?
    For every 10 ppm FC added by trichlor you also add 6 ppm CYA.
    May 2012
    NorCal
    This doesn't make sense to me. I moved to a house where previous owner exclusively used tablets for many years. Sure, CYA ended up being somewhere between 240-300 but shouldn't it have gone up to much higher number?
    After the drain and refill, CYA is now somewhere between 70 and 80.
    Hopefully this will make it easier for me to keep algaes away. I plan to keep chlorine level between 5 and 10.
    25k gal IG pool
    Quote Originally Posted by han78216 View Post
    Not necessarily. If he had a sand filter, backwashing and other water loss would limit the upper concentration. But . . . . test results showing 240 ppm CYA are highly suspect. Unless he was VERY careful and did VERY good dilutions, his 240 ppm might have been 600 ppm!
  1. CYA in Trichlor?
    By jhm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2010, 05:06 PM
  2. 94% Trichlor?
    By rhosk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2010, 11:39 AM
  3. trichlor and ph
    By itjustrixie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2007, 03:20 PM
  4. Trichlor & PH
    By Simmons99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-24-2006, 04:26 PM
  5. CYA very low, however I use trichlor
    By nicole12 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 08:13 PM
