Re: Trichlor = How much CYA?
This doesn't make sense to me. I moved to a house where previous owner exclusively used tablets for many years. Sure, CYA ended up being somewhere between 240-300 but shouldn't it have gone up to much higher number?
After the drain and refill, CYA is now somewhere between 70 and 80.
Hopefully this will make it easier for me to keep algaes away. I plan to keep chlorine level between 5 and 10.
25k gal IG pool
