Thread: Low Calcium Hardness - How to increase ?????
    Jul 2011
    Cleveland, Ohio
    Question Low Calcium Hardness - How to increase ?????
    I've read the posts whi talk about low calcium hardness and not to worry as much as long as you do not have a concrete pool. The posts also indicate that the real danger excsively high cakcium hardness. But none of the previous posts address the effect that low calcim hardness may have on conrete ( either regular or stamper/decorative) around the pool.
    My Calcium Hardness level is 97 vs. the 200-500 PPM recommended range.
    Question?
    1. Will low levels present harm to my decorative concrete surrounding my pool?
    2. What is the best additive to increase the hardness?
    Any help would be appreciated. Thanks.
    IGVL 22'x40' 33,000 gals w/ Autocover
    ~Pentair Mechanicals~
    Pump: Intelliflo VF
    Filter: Triton TR60 w/ ClearPro technology
    SWCG: IC40
    Heat Pump: UltraTemp 120 Heating & Cooling 125,000/75,000 BTU (Primary)
    Heater: 400 BTU Mastertemp (Secondary)
    Controls: EasyTouch 8 Ch. w/ load center and built in IC40
    Lehigh Valley, PA
    Default Re: Low Calcium Hardness - How to increase ?????
    Low CH can cause damage by leaching calcium out of plaster, concrete, tile, stone, and so forth. You increase CH by adding calcium chloride, sold as deicer at hardware stores, or with calcium hardness increaser sold by the pool store.
    Jul 2011
    Cleveland, Ohio
    Awesome. Thanks so much.
    Pump: Intelliflo VF
    SWCG: IC40
    You are welcome.
    Lehigh Valley, PA
    Thanks for the reminder.
  1. Calcium Hardness
    By kinetique in forum Dealing with Alkalinity and Calcium
    Last Post: 11-15-2012, 07:12 PM
  2. How much is too much for Calcium Hardness
    By Skillset in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2007, 06:49 PM
  3. Calcium Hardness
    By Ciscokid in forum Dealing with Alkalinity and Calcium
    Last Post: 05-30-2007, 03:29 AM
  4. How do I increase Calcium??
    By roll tide in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-14-2006, 12:45 AM
  5. calcium hardness
    By boscogabby in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2006, 04:25 PM
