Thread: Pool Cleaner not moving at normal speed
    Jun 2012
    Pennsylvania
    Default Pool Cleaner not moving at normal speed
    recently purchased a new Kreepy Krauly. I have had a differnet type before. After hooking it up, to the skimmer, I noticed it is not moving very fast, or at a normal speed, it moves at about 1 foot in a minute. When I turn my heater on it moves a little faster. I took it to my brothers house and tested it in his pool. It moves along normally and goes up the side wall level with the top of the water before turning. He has the same Krauly. We both have the same hp pump. I';m thinking if I put a bypass on my heater that I will gain better thru put with the water vacuum. Any thoughts? I pulled the filters in my filter system and even ran without filters in. Didn't make a different.
    Default Re: Pool Cleaner not moving at normal speed
    Can't answer your questions, but I have upgrade your membership and moved your post into the cleaning section. You can search using the link in my signature.
  1. Moving an above ground pool
    By HaleyArnold in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2012, 04:48 PM
  2. Moving a pool question
    By Pibster in forum Above-Ground Pool Construction & Repair
    Last Post: 05-07-2012, 03:55 PM
  3. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
  4. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
  5. Eliminate booster pump for cleaner with 2 speed pump?
    By breckens in forum Pool Equipment & Operations
    Last Post: 08-01-2007, 11:13 AM
