Thread: New AG pool-How To Start???
    rferrel1 Guest
    Talking New AG pool-How To Start???
    Okay - my 15x30 AG pool WILL BE installed by the end of the week (should have been done yesterday but they were missing some pieces??) by my calculation it is 13,750 gal. I have received the PS234 test kit. Here's my questions:
    1) should I pretest some of my tap water so I know where I'm starting?
    2) pool is coming with "1st 2 weeks of chemicals" - are there any things the installer might have to put in that I need to definitely say, NO, NOT IN MY POOL!!
    3) Any suggestions as to quantities of B&B&B I need to have on hand right off the bat??
    4) Any other things I need to have on hand initially.
    Sorry if these things are answered over at poolsolutions, but I don't have my subscriber access yet.
    Thanks for any info - I am so looking forward to proving to "sweetie" that I can do this without all the other "stuff". I took care of a similar size pool when I was a teenager (early 70's) but we used the chlorine tablets, etc.
    Default Re: New AG pool-How To Start???
    It sure wouldn't hurt to test your tap water, so you know your starting point--and it'll help us tell you what you need to get and be prepared to add. The only thing off the top of my head that I wouldn't let an installer put into a new pool startup would be anything that contains copper, or anything really other than chlorine, CYA, or acid.
  1. Where to start? BBB pool!! HELP!
    By HollyClo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2011, 10:15 PM
  2. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  3. New pool start up
    By micon2 in forum DPD-FAS based testing
    Last Post: 10-20-2006, 11:54 PM
  4. Pool Start Up
    By micon2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-07-2006, 10:52 AM
  5. Pool start up?
    By Trimom in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 11:04 PM
