I am unable to get my water cleared up and when the sun is out you can see little white dots floating around everywhere. When I vacuum the pool through the cartridge a huge amount of milky water comes out and clouds up the water. In the last 2 days I have been able to barely see the bottom of the pool after the pump has been of overnight but as the pump comes on it clouds up worse.
My cover slipped off of he pool during the winter filling it with only God knows what. I have been taking my water to the local Leslie's and they have been testing and giving me more chemicals to add. They are telling me that all of my parameters are in line and have given me to different types of clarifiers that haven't helped either. One of the clarifiers was blue and needed to be diluted and the other was yellow that you spray over the pool.
I have a above ground pool that is like a intex with a saltwater generator. It is 8800 gallons with a cartridge filter. I have tried the standard vac that goes through the cartridge and the catphish vac.
My last test results where
FAC 5
TAC 5
Salt 3300
CH 230
CYA 60
TA 80
pH 7.2
COPPER 0
IRON 0
Pho 0
Temp 75
All of your help would be greatly appreciated
