Results 1 to 10 of 15
Thread: help adjusting
    Default Re: help adjusting
    i am not close to a sams club but i do have a bioguard product called stabilzer 100 that i used before i found this forum. it is 100%cya. but i probably only have maybe 2 pounds. according to the label, adding 1 pound per 4,000 gallons will add 30 ppm of cya. do u think adding this much would be sufficient and get a reading before adding more? i have read on this forum to be careful about getting a high cya reading...and i dont trust myself in that i got a zero results. (but the dot never disappeared). it will be tomorrow evening before i can add this product. please advise as to whether i should proceed with this product and if 2 lbs is enough to start with. thank u for ur help!!!
    In a 21000 gallon pool 2 lbs of stabilizer will only raise the level by about 10 or 11 ppm, not enough to show up on the test. I would start with 5 lbs initially which should raise the CYA by about 30 ppm if your pool is 21000 gallons. Even if you are not at 0 ppm now but it is too low to measure you CYA won't be too high if you are not using trichlor tabs but use bleach.
    Add the CYA to the skimmer with the pump running and don't bother to test it for a week and don't backwash the filter for a week either. In the mean time keep adding bleach to maintain at least a 3 ppm FC level in the water.
    A more important question is what is your combined chlorine reading after adding chlorine. I am assuming that when you say chlorine is 0 you mean FC. Telling us both FC and CC readings and how long after adding chlorine (and how much added) will tell us a lot about what is going on in your pool.
    I don't use trichlor tabs, only beach. FC was at 0 yesterday...did not get a reading on CC.. as the sample never turned pink . i added 3 gallons of bleach yesterday and this morning at 9:30a my clorine reading with the oto was at 5, at 3p it was 2 and at 4:20p it was 0. i had to add more water this afternoon. the readings tonight at 8:15p using the taylor 2006 kit are FC 0, never turned pink, PH 7.8, TA 90, CYA...i still can see the dot at when all solution is poured into the cya cylinder. i have purchased cya now. i will add another 3 gallons of bleach now and will wait ur reply before adding the cya as i'm not sure whether to pour it in the skimmer or use the sock method and too please advise if i am still to add 5lbs or anything else i may need to do. thanks for all ur help!
    5 lbs. of stabilizer will add about 30ppm of CYA. If you have already added 2 lbs. previously, then go ahead and add 5 more lbs. That should take you up to a reading of about 40-45 which would be a good level. You can add it either of the ways you mentioned. If you do put it in the skimmer, just keep your pump running 24/7 for the next 4 or 5 days and don't backwash the filter for about a week to be sure it has all dissolved. I add it different ways, different times. This year, I put it in the sock and put the sock in the skimmer basket and kept the pump running. The sock was empty within about 3 days.
    if i put it in a sock and place in the skimmer, is it okay to add bleach to the skimmer? i add my bleach to the skimmer
    the easiest way to add the cya is to pour it SLOWLY into the skimmer with the pump running. Run the pump continusously for the frist 24 to 48 hours, don't back wash for a week, and don't bother testing it for a week. You can add bleach to the skimmer after you add the cya with no problems.
    If you do want to do the sock in the skimmer, just lift it out while you pour the bleach and then put it back in afterwards. Any of these ways to add the CYA is fine. I usually do add it into the skimmer. This is the first time I did the sock in the skimmer instead. Your choice.
