Re: Virginia Swamp!
I was doing the same thing you are. Adding just enough bleach to not do any good.
I'm betting if you increase your bleach dose to 10-15 gallons instead of your normal 6 you'll see an immediate improvement. Right now you are just spinning your wheels.
I had to add TEN of the large jugs of Wal Mart brand Bleach before I turned the worm in my favor. After that it was pretty simple. I measured my FC at 50+ on the first day, but by day 2 it had fallen to 15 ppm. So the bleach was being used up.
~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
