@PoolDoc
Yes - I really think I have most of it out of there now... tho not being able to see the bottom isn't helping...
@PoolDoc
22.5K vinyl pool, Foxx 3.5sq ft sand filter - 70gpm, Pentair Ultraflow pump retrofitted w/2 speed AO Smith B2982 1.65hp motor, Intermatic T106R timer, Watermaid SWCG @6000ppm
15x39 oval 22.5K gal AG vinyl pool; SWCG; Foxx 3.5 sq ft sand filter; Foxx/Pentair Ultraflow w/ new 2 spd 1.65 hp mtr pump; 24hrs; Taylor K-2006; delivered via truck; summer: none; winter: vinyl / water bags; ; PF:5.3
OK, where we are...
Pool 'looks' approx the same (literally NO clearer than when I started) probably a little lighter in color than it was, opaque light green, cannot see more than 12" into the water. Pool is being backwashed 3-4 times a day. I have scoured the pool for leaves and debris etc, and cannot find any significant quantities in there anymore.
Latest readings:
pH = 7.4
Alk = 140
FC = 18
CC = 3.5
CYA = 50ppm
salt @ 5200ppm
(running low on the Taylor 0871 cl test reagent!!)
at this point I've added (in total) 22.5 lbs trichlor, 15 lbs HTH Cal hypo shock, approx 80 gallons of 6% bleach, 12 lbs baking soda, and ~20 boxes 20 mule team borax.
Our well here (that I use for topping up the pool) contains IRON (clear water iron). I have recently (couple of months ago) plumbed in a new iron filter (birm media) with an 'oxygen chamber' aka a venturi (which oxidizes the iron and precipitates it into the iron filter) and a new water softener. The hose/pool water goes through the iron filter but not the softener. I am confident that this treatment system is working properly, BUT it is likely that the pool contains some iron from before when our old iron filter was not working right.
The (fiberglass molded) pool steps in the shallow end are stained orange/brown (tea colored) below the water line. This is almost certainly an iron compound (dishwasher used to get like this too). I sprinkled some 'super iron out' on the top step which has about 1/2" water covering it, and the discoloration immediately disappeared and step turned white.
At this stage I am wondering if at least some of the color in the pool is perhaps due to residual iron compounds???? It seems odd that its really no clearer that it was 2 weeks ago. (Having said that, SOMETHING is being caught in the filter).
Any thoughts?
Malcolm.
PS WM - my cute avatar is a Google Android from squishable.c*m (no affiliation)...
Cloudy green usually means algae and you also have a significant CC reading that suggests the same thing. Having said that, it could be metals as well but either way, you've got to kill the algae.
Go ahead and reorder some reagents instead of waiting until you run out. Also, quit using the trichlor. It adds CYA and your CYA is high enough.
