Results 1 to 10 of 25
Thread: A few questions for a new Intex 16 X 48 pool
    Lehigh Valley, PA
    Default Re: A few questions for a new Intex 16 X 48 pool
    The shock product you used is calcium hypochlorite (cal-hypo) which adds calcium hardness (CH or TH) to your water. Vinyl pools don't really need that and, in fact, too high a level can be detrimental. Have you added any other products to the water? I'm curious as to how the CYA (stabilizer) produced a reading on the test strip.
    Six hours on the pump and filter sounds reasonable. I run mine on a timer during the night when electricity is cheaper. Yes, you can run it with the cover on as long as the cover doesn't obstruct intake and return.
    Get some regular 6% household bleach and add 1 qt each evening; this will add about 3 ppm chlorine to your water. We cannot stress the importance of a drop based FSD-DPD test kit strongly enough. It's the only way you can know with some certainty what your water chemistry is.
    Happy swimming!
    BigDave's Avatar
    If you haven't put anything but the Super Shock and Swim in the pool, then you have no stabilizer (see why we don't trust strips). With a pool the size of yours, you might consider liquid stabilizer (also called conditioner, Cyanuric Acid). You'll probably need 1/2 a gallon to 3 quarts. It's more expensive than granular stabilizer but you won't need much.
    I'd plan to run the filter all the time there's no one in your pool. The Intex cartridges filters I had when I had my 15' donut just don't seem to deliver water clarity.
    I would not run the filter when someone is in the pool. I just don't trust the insulation on these pumps and there is no other means of electrical protection.
    You can see if you can get the HTH 6-way kit Watermom mentioned here(Check Availability). "Guess Strips" are just not reliable enough.
    It's really not hard once you get the hang of it; you're going to love your pool.
    Jun 2012
    New Jersey, USA
    I guess i'll give that a try. I only added that half pouch of shock nothing else. I'll look for the test kit today and see if it gives me different readings.
    If you don't find liquid CYA or just prefer the cheaper granular (which is what most of us use), then a 2 lb. container of stabilizer would be perfect. That amount would add about 50ppm of CYA to your pool which is ideal for most pools. It may be labeled as stabilizer or conditioner, but check the ingredient labels and make sure it is just cyanuric or isocyanuric acid and not a bunch of other stuff blended in. Let us know what you buy and we'll help with how to add it. (NOT broadcast across the pool like the label tells you to do!)
    Jun 2012
    New Jersey, USA
    Well I just got home and rechecked with the strips (didn't have a chance to get the drop tester probably tomorrow) the only thing that seemed to change was the chlorine was down Since I had only used half the bag I put the rest in and am running the filter for now. When I go up to get the test kit I'll look for the bleach and stabilizer. So I can use bleach instead of chlorine? Can I do this all the time? I'm guessing the stabilizer helps keep the Chlorine level from dropping so quickly? Sorry for all the questions just trying to understand it along with figuring out how to maintain it. Thanks again for all the responses.
    Lehigh Valley, PA
    Bleach IS chlorine.
    Yes, you can use bleach all the time. Regular, unscented, plain old bleach at 6%.
    Yes, the stabilizer (CYA, cyanuric acid) helps keep the chlorine level from dropping.
    BigDave's Avatar
    Yep, bleach is chlorine, Sodium Hypochlorite solution same thing as pool store liquid chlorine but at a different concentration. You can use it all the time, most of us do.
    Right, The stabilizer does keep the chlorine from being quickly consumed by the sun.
    How much of the cal-hypo (Calcium Hypochlorite - Super Shock and Swim) do you have left? You can use it to chlorinate for a while but it adds calcium to the pool and can cause cloudiness if used excessively.
    Jun 2012
    New Jersey, USA
    Thanks for the clarification on the bleach thing just always been told bleach is bad don't let it touch your skin! Then using it in your pool seems kind of strange. I got the 6 way test kit today and here's the results:
    Chlorine - 5
    PH - 7.5
    Alk - 120
    Hard - nil
    CYA - >30
    The hardness and CYA tests didn't seem like they worked or I don't have any in my pool because the kit says when adding the 5 hardness drops the water should turn red if present and it turns a very light yellow color so I'm guessing thats a good thing? The CYA test your supposed to mix 7 ml of pool water and 7 ml of the CYA acid reagent for 30 seconds then transfer to a tube with a black dot on the bottom. It says the solution is supposed to get cloudy, but mine stayed clear so I could see the dot even after I filled the tube to the top. I got a 6 pack of the shock and swim and from the readings it looks like it's doing the trick. Should I dilute it in a bucket of water before I add it? I'm seeing some sandy looking stuff on the bottom of the pool and I'm not sure if it's extra added stuff in the shock collecting on the bottom (not really a lot just that I saw it and thought I'd mention it) We did have a full day of rain so maybe it's just pollen from the trees. Another question the cover is a real PIA to get off without dumping everything on top into the pool any tricks to doing this? Thanks again for all the help. I couldn't find the stabilizer at Walmart, but I'm guessing thats something to use if my chlorine keeps jumping down and up right? I'm going to run the filter for a minimum of 6 hours everyday probably more once we start swimming in it (maybe this weekend?)
    If your CYA sample didn't turn cloudy, then you have little or no CYA in the water. If you have only used cal-hypo, then you haven't added any CYA yet. You'll need some, about 40-50 ppm. Not only if your chlorine "keeps jumping up and down." All outdoor pools have to have some or you won't be able to keep chlorine in the pool especially on hot sunny days. You can either buy some and add it directly or use a stabilized form of chlorine for awhile that will add CYA and chlorine at the same time. The choice is yours. Both ways are just fine. If you decide to add it separately, it may be labeled as conditioner or stabilizer. Check the label; the ingredients should say cyanuric or isocyanuric acid. You'll need 2 lbs. You can put it in an old sock and hang it in front of a return jet and give it a squeeze once in awhile to help it dissolve faster. Remove the sock from in front of the jet when you add other chemicals through the skimmer, however.
    If you decide to use a stabilized form of chlorine instead, you can either buy dichlor shock powder or trichlor pucks. I'd suggest the dichlor, though, as it will get the CYA in there faster. If you have access to a Sam's Club, you can buy their 24lb pack of 1# bags of 100% dichlor shock. Each bag will add about 7 ppm of chlorine, and about 6 ppm of stabilizer, per 10K gallons of water. (You won't need all the bags this year, but you can save it til next year.) Otherwise, order dichlor from Amazon:
    Kem-Tek Dichlor 22 lbs
    We do NOT recommend buying dichlor locally, otherwise, at least until you are an EXPERT reader of chemical labels. The chlorinating pool chemicals sold at Walmart, Kmart, Costco, and most other local stores are diluted blends, sometimes with copper and other products with bad side-effects.
    (After your CYA gets to around 50, you'll want to quit using dichlor and switch to bleach so your CYA doesn't get too high.)
    Don't worry about the hardness test for now. But, if you decide to continue using the cal-hypo instead of using dichlor, you'll want to monitor it to make sure it doesn't get too high which can cause cloudy water problems.
