Results 1 to 10 of 32
Thread: Run around at pool store
Threaded View
  1. #2
    Default Re: Run around at pool store
    First off, welcome to the Pool Forum! Secondly, stay out of the pool store. They exist to make money so of course, they are going to keep finding products for you to buy. My guess of what is going on with your pool is that you have used stabilized chlorine for a long time (trichlor pucks, dichlor shock powder) and the CYA level in your pool got really high. Then, over the winter, the CYA biodegraded and left you with a pool full of ammonia and an unsatiable chlorine demand. We see this every year and this year has been particularly bad. Any idea what your CYA reading was when the pool closed in the fall? Any idea what the CYA level is now?
    We really can't do too much without a good set of current water testing results taken with a drops-based kit. The kit we really prefer is the Taylor K-2006 or 2006C which you can get through the test kit link in my signature below. However, it is only available online so you'll need something to use while you await its arrival.
    For now, get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    While you are at Walmart, buy several jugs of plain, unscented bleach (generic is fine) and a couple boxes of 20 Mule Team Borax (laundry aisle).
    It's much easier to answer your questions, when we know something about your pool. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    Repost and let us know which test kit you get and give us some current numbers and someone will try and help you go from there.
