Thread: Mineral Springs system not generating.
    Jun 2012
    Austell, GA (Metro Atlanta)
    Default Mineral Springs system not generating.
    My Mineral Springs system continues to show "no flow". We balanced the water & got it right, then added the salt. Still shows "no flow" & I am afraid we just wasted $100 worth of salt? Any help on trying to troubleshoot before $140 for a new flow switch? We are new pool owners & don't have a clue. Sorry!
    Default Re: Mineral Springs system not generating.
    Let me move this so Waste, Waterbear and PoolSean can see it. Mineral Springs is BioGuard's proprietary model, and they are pretty sparse on the service info. But I think those guys know who makes what. You may have to be patient; we have just been swamped with new traffic.
    The good news is, if your chemistry is set up correctly to the SWCG . . . it will be VERY easy to run manually, till you get your unit worked out. And, it's much easier to answer questions, when we have the details about your pool in one place. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    Also, if you'll tell me HOW you test, and give me your current test readings, I can help you with a quick and dirty recipe for treating your pool, so you can use till your SWCG comes back online.
    First let me say that until you get the unit working again PLEASE do what PoolDoc asked so you can chlorinate your pool manually so you do not have problems.
    The mineral springs units were rebranded Goldline units (Hayward) and looked like this:
    IF that is what yours looks like then the flow switches do go bad or get fouled with calcium. They really cannot be cleaned when this happens but should be replaced, IMHO.
    Here is a short video that shows you how to do it properly.
    Oct 2013
    South Caolina
    Thanks for the video. Any ideas where home owners can purchase said flow switch?
    You can purchase it through a BioGuard dealer for $$$.
    You *probably* can buy it, as a Hayward/Goldline part, if you can work out exactly which Hayward model it corresponds to.
    Largo, Florida
    Does the switch look like this?
    That's the Hayward switch. There's nothing special about it. It's a simple inductive switch with two wires connecting through an rj11 "phone" connector on the control board. When water flows through the line, it physically pushes the metal tab into the other lead and closes the electrical circuit. I got an aftermarket switch when I replaced mine last year, but I'm pretty sure I paid more than the Hayward part is going for on amazon now: http://www.amazon.com/Hayward-GLX-FL.../dp/B0030E3US2 .
