I have a Hayward S200 sand filter with a side mounted SP-710 valve. This valve is old and has some small hairline cracks in it. A few years ago I got a new SP-710 valve, but it was the wrong one. It doesn't have the tubes that go from the valve to the filter. Since I needed the internal valve assembly at the time, I swapped the top half out and it worked fine. Now the leaks from hairline cracks in the valve body are getting worse and I want to replumb everything. Is there any way to adapt this new valve body to my filter? I think the one I'm wanting to use is a 710X meaning it just has 1.5" threaded connections. I'm not exactly sure what the fittings are on the filter. I'm just trying to save $100+ for a new valve. Thanks.
