Thread: Install gone wrong? Patio Blocks felt under liner
    Jun 2012
    St. Louis
    Default Install gone wrong? Patio Blocks felt under liner
    Ugg.....We had an 18' above ground pool installed last weekend and one side of the pool had to be raised 1 1/2 feet. The company used a mixer of dirt and sand to do this. They proceeded to install the pool on 12" patio blocks under each post. Now that we were able to use the pool, we 2 of the patio blocks through the liner....the sand has seeped out from the high side of the pool where they had to raise it. Of course, the installer isn't returning my calls.
    Any suggestions on how to fix? Or should we empty the pool and have the base redone?
    Default Re: Install gone wrong? Patio Blocks felt under liner
    Sorry, upgraded your membership, but then didn't get thread moved. All done now, so everyone can see, and you can post. (Sorry, but I can't answer the question myself.)
  1. Bleached out liner - What did i do wrong?
    By Orion in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2011, 09:11 AM
  2. AGP Install Question - Blocks under entire rail???
    By Stonedbeetle in forum Above-Ground Pool Construction & Repair
    Last Post: 05-25-2011, 11:55 PM
  3. liner install help?
    By jazzbone in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2010, 07:55 PM
  4. patio blocks really needed at every brace in hardpan soil?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-29-2007, 06:51 PM
  5. AG Liner Install
    By snapperbig in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 02:50 PM
