This is a quote of your suggestions to clear some tough cloudy and green water.
Here were the results of my fill water test.
Chlorine - 0
Ph - about 7.0 (I think - the color was a really pale pink)
TA - 310-320
TH - 210
I have done the bucket test (not quite finished) on the fill water and the pool water. Here is what I've got.
Fill water started out clear. Once adding bleach it took on a yellow tint but still clear. After 15 min, it was still clear but a bit more yellow. I added the borax. After 24 hr, the water was still yellowish and clear with sediment on the bottom in the center. After 24 more hr, it was still the same. Tested with OTO and it was very splotchy orange...very strange. The next three days are up tomorrow.
The pool water started out whitish and very cloudy. Once adding bleach it stayed the same. After 15 min, it was still the same. I added the borax. After 24 hr, the cloudy water was gone!!! It had sediment on the bottom too, but not as much as the fill water did. It looked a slightly filmy on the surface. After 24 more hr, it was still the same. Tested with OTO and the water was splotchy orange, but not quite as bad as the fill water. The next three days are up tomorrow.
I have not put anything in the pool except chlorine bleach and muriatic acid.
I have kept the chlorine above 5.0, but it's been very hard. It has been raining ALOT in the Houston area. So much so that it's been hard to get outside and take care of the pool. It's pretty green again too. Algae again??? Today, I got the chlorine high again with the OTO in an orangish color. The skimmer is floating (not hooked up) with the high water. I took the bucket out and it looked pretty yellow. I also noticed the small separation in the liner above the seams at the top have little bits of water and lots of algae sitting in the area. What do I do with that?
I got the Unicel cartridges. I've been using them a few days now. Absolutely no better than the INTEX yet.
I've been adding the acid keeping the ph around 7 or just below and the TA has come down to 170 the last time I checked (was over 240).
I've been filtering most of the day, but my husband unplugged it some when it rained.
I still don't know what to do. I see no change or possible improvements. I know the rain has made things harder. I'm afraid the algae came back due to the green color and I don't know how to get rid of the algae in those tiny crevices. Which could they reinfect the pool?
So any ideas? This is getting really ridiculous.
