Re: Cloudy water not clearing
How consistently have you been keeping the chlorine in the orange range? You state in your post above that it has been difficult to tend to the pool with all the rain you have been having. Killing algae requires consistent high chlorine. You cannot let it yo-yo up and down or else you will never get rid of it. Have you brushed the pool daily while the chlorine level was in the orange range? Are you testing it every day, every other day or ???? How often are you adding bleach?
If it were my pool, I'd be testing it at least three times a day, and each time adding enough bleach to get it back into the orange range. You are wanting your chlorine to stay at around 15-18. You can use the dilution method I linked for you back in post #9. Sustaining high chlorine levels is the key to killing algae.
