Results 1 to 10 of 19
Thread: Cloudy water after filter change
    Default Re: Cloudy water after filter change
    You can use dichlor but just be aware that as the CYA level comes up, so does the needed shock level to kill whatever is in your pool. If you haven't already done so, please read the Best Guess Chlorine Chart in my signature. I would also suggest a CYA level of around 50 as opposed to 30. (Actually, maybe aim for 40-45ppm and that way if you overshoot a little, you'll still be ok.)
    Jun 2012
    Great. Thx!
    Also, forgot to add that you'll also need to watch your pH as well. Dichlor (and trichlor for that matter) are both acidic and will drive the pH down.
    Hi Jim;
    Here are some things that may help:
    1. Link to the chlorine demand bucket test -- it will allow you to estimate how much further you have to go.
    2. Links to our online pool history chart -- if you add the data, I'll turn on the graphing:
    Pool History Chart
    Pool History Results
    3. Links to the online pool chart, allowing us quick access to your physical pool info:
    Pool Chart Entry Form
