Thread: Summer Splash through skimmer/filter/pump problem
    Jun 2012
    Kentucky
    Default Summer Splash through skimmer/filter/pump problem
    Has anyone hard piped this to an intex sand pump? I am having problems find the right adapters to go from the skimmer to the sand pump since the old pump attaches to the bottom of it.
    Default Re: Summer Splash through skimmer/filter/pump problem
    Do you mean "Summer Escapes", which is Sams's Club Intex-like pool? I'd suggest calling them to find out if it IS an Intex pool.
    If it is, then you can go ahead and get the filter, though you may not be able to find out what adapters you have to order till you have both the pool and the pump & filter.
  1. Replies: 10
    Last Post: 07-10-2011, 05:17 PM
  2. Sand Filter/Pump problem - AG
    By AnnaK in forum Pool Equipment & Operations
    Last Post: 05-29-2007, 08:51 PM
  3. Need pump, filter and skimmer recomendations?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 11:17 PM
  4. Pump/skimmer Or Filter Problem - Not Sure
    By niklepikle in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 11:33 AM
