Results 1 to 10 of 22
Thread: Looking for pool shocking information from Ben Powell.
    Jun 2012
    East Coast of MN
    Default Re: Looking for pool shocking information from Ben Powell.
    I have posted everything but the pump model. I have been using guess strips and a drop kit for Chlorine and PH. I will be looking asking my wife about buying the K2006 or K2006C from Amazon this weekend.
    Current readings from guess strip are PH 7.2 after adding a box of Borax, Total Alkalinity 120, Chlorine about 9 and Stabilizer 100. With the drop kit Free and Total Chlorine both are off scale and PH reads about 7.5 after a box of Borax. Next question are the chemicals good for more that one year in the K2006C?
    Tom
    Quote Originally Posted by burtom View Post
    Yes.
    Also, your stabilizer could actually be much higher than 100. Tests can't differentiate readings past that value. Order the K-2006 and then run the CYA test on a diluted sample. Take one part pool water and mix it with one part distilled water. Use that water for the CYA test and then multiply the results by 2. If you still get a reading of 100, repeat it but use one part pool water and two parts distilled water and multiply the results by 3. That will help to give a better idea of what your CYA level actually is.
    I'd recommend starting with a 1:3 dilution (multiply x 4). He'll use up his CYA reagent getting there, otherwise. (One of the weak points in the K2006A is that it contains only 6 x CYA tests.)
    Jun 2012
    East Coast of MN
    Thank you everyone I have ordered the K2006A kit and will be back with results.
    Tom
    Good deal!
    Jun 2012
    East Coast of MN
    Hi Everyone:
    I did my testing with the kit and the results are:
    1.6 PPM Free Chlorine
    .2 PPM Combined Chlorine
    7.7 PH
    160 PPM TA
    140 PPM Calcium Hardness
    228 CYA
    Tom
    gas heater
    "18'x36' rectangle 25K gal IG vinyl pool; Skimmer Tabs; System3 Filtration S8S70 sand filter; pump; 24hrs; Aqua Chem 5 way test strps
    Aqua Chem 3 way kit; well; summer: none; winter: mesh; ; PF:4.8"
    That's a really odd reading for the CYA. How did you get that result?
    Here's the Taylor video: K2006 Cyanuric acid (CYA) test
    Check again, and if that result is correct, you need to read the Best Guess page, linked in my signature, right away.
    Good luck!
    results are:
    FC 1.6
    CC 0.2
    pH 7.7
    TA 160
    CH 140
    CYA 228
    Ok. Well, your water is OK, except for the super high CYA. Here are your options, 2 with draining, and 2 without:
    1. Drain and refill. This is NOT recommended on a 20 year old vinyl pool.
    2. Do an in-pool drain and refill. Slow and requires a vinyl winter cover that's about 12' wider than the pool on all sides.
    3. Run a HiC2 pool -- high chlorine to compensate for your high CYA. That's OK, but it means NORMAL chlorine levels will be around 15 ppm on your pool and shock levels will be about 30 ppm. This should be pretty easy with the K2006, so long as you have no algae. But, to get rid of algae might require FC = 60 ppm!
    4. Run a sorta HiC2 pool -- high normal chlorine (15 - 20 ppm) but with sodium bromide and polyquat on hand to use, instead of having to push FC levels to 30 or even 60 ppm.
    If I were you, I'd opt for #4, but it's up to you. Regardless, with options #3 or #4, you don't want your CYA level to keep climbing, so you've got to switch to bleach (or 10 - 15% 'liquid pool chlorine', if it's available) OR calcium hypochlorite granular. Using calcium will require special methods -- not hard, just different -- to avoid replacing high CYA levels with high calcium levels.
    One HUGE downside to the HiC2 method: if you let your pool get slimed over the winter, there is an good chance that the CYA will be converted by bacteria to ammonia over the winter, leaving you with so much ammonia that it would literally take 400 ppm FC to clean up in spring. So, you can NOT allow the pool to slime over the winter. Closing clean, plus using repeated polyquat doses over the winter, plus Minnesota temps should make this easy, if you just pay a bit of attention to the pool after closing.
    Lemme know what you want to do.
  1. Pool is green, wanting information on BBB practice :)
    By mcdon294 in forum Dealing with Algae & Slime
    Last Post: 09-09-2012, 09:19 PM
  2. Looking for information on Trevi 21' pool
    By oldcow in forum Above-Ground Pool Construction & Repair
    Last Post: 04-08-2012, 08:16 PM
  3. Installing a new pool, looking for information on UV sanitization systems
    By Rakfiddad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-01-2011, 02:50 PM
  4. Information overload on buying AG pool!
    By idohair2 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-10-2011, 09:57 PM
  5. useful sites for pool information
    By LBD in forum General Interest
    Last Post: 04-23-2006, 11:41 PM
