Re: Would a water softener remove iron and metals?
The water softener will remove the iron but the resin will be quickly depleted if you are trying to fill a pool. Normally a separate 'green sand' filter is used either alone or in conjunction with a water softener to remove iron. Green sand is a special filter medium (manganese green sand) used in water treatment to remove iron, manganese, and hydrogen sulfide from well water and is usually in a whole house filter canister.
