Results 1 to 10 of 42
Thread: Water "Color" Problems!! Ready to give up!!
    Jun 2012
    Nebraska
    Default Re: Water "Color" Problems!! Ready to give up!!
    We were suprised at how much better the water looked yesterday evening! It is still green but seems to be getting a lighter green and it was much more clear.
    I'm not sure if my vacuum isn't very good but when we vacuum the bottom it seems like it reallys stirs things up and then the water gets really cloudy. Not sure if I need to get a different vacuum or what. We have a wheeled one, the suction doesnt seem to be real great when we use it though.
    Another question, what is the best way to take the filter out. When I take the filter out to clean it, it leaves behind a brown gross mess in the water. I shut the pump off when I pull it out, I rinse the filter out and then put it back in and turn the pump back on. Then all of that gross brown water gets shot out into my pool. It seems like there has to be a better way.
    I am going to make my husband add the pH down this evening. I'm kind of scared to touch the stuff Do we need to dissolve it in a bucket first? Or just toss it in?
    My readings this morning:
    pH - 8.2
    Ch - .5
    TA - 340
    Hardness - 360
    CYA - dot didnt disappear
    Thanks again for all the help!
    15' x 48" 4,300 gal Intex AG pool; PF:27
    16' round 4.5K gal AG pool; Trichlor granules ; Unicel - C cartridge filter; Unknown pump; 24hrs; Walmart hth 6 way test kit. ; well; summer: ; winter: ; ; PF:27
    It would be best to dissolve it in a bucket.
    Regarding filters, if you will get 2 or 3 of THESE cartridges, you'll get much better performance, and they will last all season:
    Unicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ Amazon
    Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
    The Unicel's filter better than the Intex cartridges, and should last all season. One caution: many online pool company's are shipping non-Unicel cartridges, but showing the Unicel number. Do NOT purchase a a cartridge, if the company lists OTHER brands, except Intex OEM specs. (If Filbur, Pleatco, etc. are listed . . . do NOT buy. Filbur is OK, but what you'll get is almost certainly a Chinese cartridge that's even LOWER quality than the Intex OEM!).
    I'll try to get a filter cleaning sticky posted in the Equipment section, today.
    I'm not sure (and haven't looked) to see just what filter you have. But you should be able to flush the filter, on most newer Intex pools, by bleeding water out of first one pipe, and then the other, while the filter is open.
    Jun 2012
    Nebraska
    I do have the Unicel filters that I bought from Amazon.
    This is the pool that we have
    http://www.walmart.com/ip/Summer-Esc...osaic/19414900
    There is only one pipe that runs from the filter.
    1. Open the filter.
    2. Open the valve that runs from the filter to the pool. Let it flush that line, out the filter opening. Close the valve.
    3. Open the valve on the line that runs from the pump to the pool. Let it flush that line, out the filter opening. Close the valve.
    Jun 2012
    Nebraska
    Talking Re: Water "Color" Problems!! Ready to give up!!
    Our water is absolutley crystal clear!!! I am still getting some brownish stuff at the bottom daily and my filter is almost always full of brownish gunk but the water is perfect! We are still working with the pH but otherwise it is perfect!!
    Now aren't you glad you didn't give up?? We are, too! Enjoy your pool
    Jun 2012
    Nebraska
    Cool Re: Water "Color" Problems!! Ready to give up!!
    I am so glad we didnt give up! My next question is: how often and how much do I use the polyquat now that my pool is clear?
    Thanks!
