Hi!
What sort of caulk did you use?
Many caulks are not good for wet use, so if it was actively leaking when you applied the caulk, that may be why you still have the leak.
As a bit of info : as long as the liner and gaskets are good behind the faceplate and skimmer body, they won't leak.
Let's look a little more into this - please respond and I'll do my best to talk and walk you through this.![]()
