Thread: need advice on what do to first
    Jun 2012
    OH
    Default need advice on what do to first
    Hi...I have a 5,000 gal. alberca pool. I use chlorine to sanitize. Here are my first readings from the
    "pool" store. What to do first????
    free chlorine 0
    total chlorine 0
    ph 7.8
    TA 270
    Cyanuric Acid 5
    Phosphates 400
    I like what I am reading on this forum, and am very excited about being responsible for my own pool without the badgering of pool store employees to buy yet another chemical to help 'fix" my pool! Thanks in advance!
    Default Re: need advice on what do to first
    Put some chlorine in the pool before it goes green!! Seriously, you need to be keeping 1-3 ppm (I would keep it more like 3-6 ppm for wiggle room) in the pool all the time. Don't worry about the phosphates, the TA or the pH for right now. Get some chlorine in there!!
    How are you testing your water, and what type of chlorine do you use? Also, we can help you a lot better without "wasting" posts trying to get needed info if you'll take a few seconds and fill out this chart about your pool.
    Pool Chart Entry Form
    Pool Chart Results
    Welcome to the forum!!
    Jun 2012
    OH
    How many gallons liquid should I put in it? I am having filter problems and trying to get them resolved today...How many tabs should I keep in my floater?
    Lehigh Valley, PA
    1 gallon of 6% regular unscented bleach adds 6 ppm free chlorine to 10,000 gallons of water. Half a gallon will do the same for your 5,000 gallons. The tabs in the floater will keep adding chlorine, which is good, and will add stabilizer (CYA) which you need to keep the sun from destroying the chlorine.
    Jun 2012
    OH
    Are the HTH pool water testing kits not accurate?? Thanks.
    The HTH 6-Way kit is, but it just doesn't test too high ----- only to 5ppm. Good as a starter kit, though, while you wait on the delivery of a Taylor K-2006! (We don't like the test strips, though.)
  1. Hot tub advice
    By myatinsel in forum General Interest
    Last Post: 10-19-2011, 03:02 PM
  2. Hello All need some advice.
    By 55fordtruck in forum Dealing with Algae & Slime
    Last Post: 08-19-2011, 10:28 PM
  3. Need some advice
    By sherron100 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:33 PM
  4. 18' AG Advice
    By cramar in forum Above-Ground Pool Construction & Repair
    Last Post: 11-19-2010, 03:05 PM
  5. Advice please.
    By savdoc2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2006, 07:58 PM
