Re: small intex 2,000 gallon above ground
Is this a chlorine, or Bacquacil pool? If you'll post a set of tests taken with a drop-based kit (we really recommend the K-2006, or at the very least, the hth 6-way drop test from WalMart) we'll be glad to help. While you're at it, please take about 30 seconds to fill out this form with your pool's info so that we don't waste a lot of time asking questions to try to get the info we need...
Pool Chart Entry Form
Pool Chart Results
