Re: New Member, yucky pool
Hi! I thought I'd answer in case Ben isn't able to before you go to Walmart, because I just bought all this stuff a month ago to open my ag pool too.
== OTO test kit
== 1 jug of stabilizer (hth stabilizer & conditioner looks like this)
== Several (as many as you feel like buying/storing at a time) gallons of plain unscented 6% bleach, store brand is fine
== 1 box of 20 mule team borax (laundry isle). This is in case you need to raise your ph. Not sure how much you'll actually need until you test your water's ph but might as well have it on hand.
== 1 box of baking soda. This is to raise alkalinity. Won't know how much, if any, you'll need until water is tested. (If your store has the hth 6-way test kit that Ben mentioned, get one of those)
== Acid. You won't know how much, if any, you'll need to add until you test your water's ph. It's something you'll need on hand though so you can go ahead and get a jug. You can either go with muriatic acid (liquid) or dry acid (at walmart it's called hth ph minus looks like this aka sodium bisulfate)
And that should be your pool supply staples for the season.
18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
; community; PF:16
