Thread: starting old pool
    Jun 2012
    VA
    Default starting old pool
    first, thanks, this site is really useful. Problem: inground circa 1984 sylvan 25,000 gal pool with 5 yr old sand filter just emptied, powerwashed and re-painted it. filling it now. I would like to try the BBB method but am wondering:
    1. Can get a testing kit locally (Walmart, pool store) or do I need to send away for your recommendations?
    2. Where can I get BB in bulk?
    3. Any other recommendations?
    Thanks in advance
    Default Re: starting old pool
    The Taylor K-2006 or 2006C is only available online. You can get one through the test kit page in my signature below. But, while you are waiting for it to arrive, get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    When you want to get BB in bulk, what specifically do you want?
    It's much easier to answer your questions, when we know something about your pool. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    Welcome to the Pool Forum!
    membership upgraded. -ben
  1. New Member Starting Pool Project
    By Lburg in forum Above-Ground Pool Construction & Repair
    Last Post: 11-06-2012, 10:06 AM
  2. New Pool & Starting From Scratch!
    By tnt69 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-04-2012, 04:59 PM
  3. Starting the pool process
    By hop6868 in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2011, 02:45 PM
  4. Walls of oval pool starting to bow out
    By kwazy in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2007, 12:40 PM
