Thread: New Pool Owner - Please help identify my pump / filter configuration
    Jun 2012
    Florida
    Default New Pool Owner - Please help identify my pump / filter configuration
    I have been reading as much as I can and have got a pretty good handle on pool care, but there are some valves on my pump / filter and I don't know their purpose. Before I backwash or do anything, I'd like to know what they are for, and if I need to adjust them first. Specifically there are 2 valves and a pipe that I need help with.
    I have a 36 sq ft DE filter, a 1.5 HP pump, and an 18,000 gallon pool with a spillover spa.
    Below are photos of my system. I have numbered them as follows:
    1) DE Filter
    2) pump
    3) Filter basket
    4) Unknown valve *
    5) Chlorinator compartment
    6) Unknown valve *
    7) multiport valve
    8) unknown pipe *
    * I need help with these
    Thanks!
    Photo of whole configuration:
    http://i1174.photobucket.com/albums/...pump_whole.jpg
    Close-Ups of the 2 valves:
    http://i1174.photobucket.com/albums/...n22/valve1.jpg
    http://i1174.photobucket.com/albums/...n22/valve2.jpg
    Default Re: New Pool Owner - Please help identify my pump / filter configuration
    Hi and welcome to the Pool Forum! Sorry you haven't gotten a reply yet. We have been swamped. I wish I could answer your question for your but plumbing is not my thing. I just wanted to pop in here to say hi and let you know that your post had been read and you aren't being ignored. Hopefully somebody will be along soon who can help you!
    Hope you enjoy being a part of the forum!
    Jun 2012
    Florida
    Hi, and thanks for your welcome note. I'll just wait and see if anyone can help.
    #4 -- your suction side connections, possibly to a skimmer and a main drain. You can find out, but rotating the valve to block each pipe in succession.
    #6 -- your pressure side connections, possibly to two in-wall returns. Check, as above.
    #8 -- no clue.
    It's also possible, that #4 & 6 allow you to switch from spa to pool, and vice versa.
    Uuhhhhh ....... What he said! This is why I told you plumbing is not my thing!
  1. Pump and filter set up, what else do I need? New Pool Owner - 33' AG
    By stack_climber in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-30-2011, 09:27 AM
  2. Changing configuration of IG pool....
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2007, 02:24 PM
  3. Pool Leak - how to identify and fix
    By Mariza in forum In-Ground Pool Construction and Repair
    Last Post: 04-25-2007, 01:11 AM
  4. Correct AutoPilot Install Configuration
    By ohpoolboy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-03-2006, 10:42 AM
