bleach is 6% concentrate and chlorine at orcharde supply is 10% and cost is not much higher
If it is 10% sodium hypochlorite and a better price and fresh, they buy it. One thing I will tell you is that higher concentrated sodium hypo sometimes isn't the percentage it is advertised at especially if it isn't fresh. Here's a way to test the concentration of your bleach...I copied this from CarlD, one of the other mods, that had posted it a long time ago...
Put ten liters of tap water ( That's 5 soda-bottles full) in a 5 gallon bucket.
Test that water for chlorine using the FAS-DPD test to get a chlorine baseline (you may have some).
Then I take a 1 ml eyedropper full of the LC or bleach I'm testing and put it in the bucket and mix it up.
(1 ml in 10 liters of water is the same as putting 1 gallon of LC in a 10,000 gallon pool -- it's 1/10,000th. )
I then measure the bucket with the FAS-DPD test just like pool water. Of course, subtract any chlorine you measured in the tap water.
I use a glass eyedropper so it will hold up. Pharmacies sell them.
been shocking pool like u recomended & still have alge or stain.water is crystal clear. been adding 3gal of 10% chlorine everynite. have a reading of over 23 ppm. next morn reads 20ppm. combined chlor is o. all my other chemicals r right on. lose about 10ppm chlor thoughout the day.
If you're still losing 3 ppm of chlorine overnight, then you're still fighting something in the water and need to maintain the shock level.
