Thread: Test results - look good?
    Lutherville MD
    Default Test results - look good?
    After a very warm winter, we were surprised that our pool opened pretty clear (lucky us.) Here are the results (and I know I need to add more chlorine...)
    29000 gal plaster pool, sand filter, inground
    CYA = 35
    TC & FC = .2
    pH = 7.5
    TA = 86
    Adj. TA = 75
    Hardness = 265
    I think with the exception of the chlorine, the other results may be good, but I need to be sure. Pool store is saying the TA needs adjusting.
    Thanks for your help.
    Default Re: Test results - look good?
    I think i would bump the TA up some with some baking soda. You may also want to increase the CYA a little to around 50ppm if you find that you are having trouble keeping a chlorine reading through a hot sunny day.
    Lutherville MD
    Thanks Watermom! Will do that - for some reason the pool store wanted me to add lots of stabilizer and "Burn Out". I'll go with the CYA and baking soda..
    Actually, stabilizer is CYA, so they were right about that, but just don't add LOTS of it! Probably about 3 lbs. of granular cyanuric (or isocyanuric) acid should be about right.
  1. looking for a good test kit
    By ynotme in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2013, 01:14 PM
  2. just got good test kit. HELP PLEASE
    By shub_31 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-24-2011, 07:33 PM
  3. Test results are good but water is cloudy
    By Crispyc21 in forum Dealing with Algae & Slime
    Last Post: 09-14-2006, 11:56 AM
  4. New Kit Owner - First Test Results - Not Good
    By Nevets in forum DPD-FAS based testing
    Last Post: 08-03-2006, 07:40 PM
  5. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
