Help with trying to understand how to get Alkalinity lower
I guess I am lost with getting the Alkalinity lower or do I need to do that?? here are my numbers and what I did from the start of setting up the pool.
Date Chlorine PH Alkalinity hardness CYA
6/9/2012 0 7.8 300 400 water stayed clear
6/10/2012 0.5 7.8 330 400 NA Added 9oz of CYA after reading
6/11/2012 3 7.5 300 370 less then 30 Added 9oz of CYA after reading
6/12/2012 3 7.5 280 390 35 12 hours boost over night before readings
6/12/2012 1 7.5 NA NA NA 2 hours after adding 12.0 oz of liquid Muriatic acid
6/13/2012 1 7.2 270 350 NA next moring after adding 18.4 total oz of MA
6/13/2012 5 7.2 NA NA NA added 8oz of shock
6/14/2012 1 7.2 300 370 NA added 6oz of shock after reading
6/15/2012 3 7.2+ 290 360 42 Changed SWGR to 7 hours before reading- no swimmer on 6/14
6/18/2012 1 7.2 230 380 35 No swimming all weekend, 2" of rain over weekend
6/19/2012 5 7.5 280 380? less then 30 added 1 gal liqued bleach before reading- reading 2 hours later
6/20/2012 added 9oz of CYA
6/21/2012 1 7.5 250 370 less then 30 1" of rain before reading- added 9oz of CYA after reading
6/22/2012 0.05 7.5 260 340 75 added 1/2 gal of bleach
6/23/2012 3 7.5 260 380 60 no swimming added 20lb salt. Keeps saying low salt??
6/24/2012 1 7.5 240 NA NA b4 reading added then 64 oz bleach and 13oz acid-& cleaned SWAG with vineger
6/24/2012 5 7.2 230 NA 60 3 hours after doing the above- SWG is running good now.
