Re: Intex Pool 18 x 48 a general question
I'm sure one of the others will chime in shortly, but I suspect it is a grounding issue....a friend of mine down the street has an Intex, and the power cord running from the motor plugs straight into a regular wall socket--no other grounding that I can see. Since electricity and water don't mix, I suspect it's just a safety issue. But...that's just my guess.
