Thread: How do you cool the water in your above ground Pool????
    Jun 2012
    St. Louis
    Angry How do you cool the water in your above ground Pool????
    I'm new to pool ownership and live in the midwest. I have an 18' 52"high above ground pool and the water is crystal clear and looks really refreshing, however once you get in it's like a hot tub!
    Was wondering what to do to keep the water cooler.....I have an open backyard with no shade.
    Thanks for any help!
    Lehigh Valley, PA
    Default Re: How do you cool the water in your above ground Pool????
    Just run your pump at night. Circulating the water past the pool sides will cool it down if your night temps are cool. You don't necessarily need solar panels.
    Jul 2011
    Boca Raton, FL
    I have a friend who places gallon jugs of water into his chest freezer, then tosses them into his pool after they've frozen solid. He says it can make a dramatic difference.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
  1. keeping above ground pool cool
    By scorpchic77 in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2013, 09:42 AM
  2. Solar heater - could it also cool water a little?
    By George in GA in forum Pool Equipment & Operations
    Last Post: 06-06-2012, 12:30 PM
  3. Keeping Pool Cool
    By GatorPharm in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-27-2010, 11:47 PM
  4. reflective cover to keep pool cool???
    By bparks in forum Pool Equipment & Operations
    Last Post: 07-18-2006, 07:56 PM
