Re: To go to salt or not..lots of questions.
If you're choosing chlorine because I suggested you add some to your fresh water, PLEASE DON'T. If it's your choice, then it's your pool but don't go that way because of my post. I have no knowlege of indoor pool care and my post was only a reaction to your fresh fill with nothing in it to prevent algae.
Pool Doc does know about these things and I think you should consider his advice.
Did you see the picture of the service panel Pool Doc posted? Is this the same building where you and your family sleep? I do know something about house wiring and can promise you that corrosion in electrical connections will cause fires. It's not the smell you should consider but the potential for disaster. If you don't have a clear and certain plan for the elimination of chlorine oxidisation byproduct gasses and a plan for regular inspection and remediation of electrical fixtures, please don't chlorinate your indoor pool.
