Re: Eradicating Water Mold / White Mold in a PHMB (Baquacil / SoftSwim / Splashes) Po
All,
thanks for the recommendations. I read the thread ACIAM posted and it gave me an idea I'd like to run by you all.
My pool has a spa connected to it. I was able to drain and refill the spa and my spa has 4 return lines/jets. I have not run the pump since adding the water nor have I added any chemicals - the water in the spa is super clear while the water in the pool is not. I added 6500 gallons of water to the pool and spa with the majority going into the pool.
What I add the chlorine or sodium percarbonate to the spa only and run the pump and the blower for the jets? Could I knock out the goo in the filter and the plumbing for the spa with this method? If yes, then I only need to worry about the to returns and main drain for the pool as far as goo goes.
I am thinking the right way?
C. Chase
