Thread: intro
    Jun 2012
    Wisconsin
    Default intro
    Hi, I'm new to the forum and new to an above ground pool. Pool is being installed this Friday so I don't have any questions yet but I'm sure I will soon. Posting so I can search about the nature2 system.
    Default Re: intro
    We do NOT recommend the Nature2 system. It adds metals to your water. You not want metals in your pool! I'd think again about using that. You are welcome to do some searching and read some previous discussions that have been on the forum. Use the google search in my signature below instead of the search feature that is part of the forum software. Until your registration is completed, you'll have to log out to be able to see the search results, however.
    Hope you change your mind about using it.
    What size is the pool you are installing, what size pump and what type and size of filter are you getting. Many AG pool packages are sold with badly mismatched pump/filter combinations.
    Welcome to the Pool Forum!
    Default Re: intro
    Just to explain a bit, the Nature2 System is an expensive, 'do almost nothing' system. Most people we encounter apparently can't tell when their cartridge runs out!
