Thread: New/Used pool start up-newbie-help needed
    Jun 2012
    New York
    Default New/Used pool start up-newbie-help needed
    Last year I purchased a used 18' x 52" above ground swimming pool. It was manufactured in 2008 by Delair model Symphony series. Along with the pool came a Hayward Perflex model EC40ACDE filter with a Hayward powerflow matrix pump. I had the pool professionally disassembled and stored and then we had it professionally reinstalled at my house yesterday. The only thing we added new was a pool liner. The pool contractors added about 3" of my house well water to straighten the liner and tomorrow we are having a bulk water delivery of chlorinated water. I believe it is taken from city tap, but was told that it was chlorinated water. A couple of quick questions...
    What should my process be for treating the pool chemistry on such short notice?
    Can I buy a water test kit from Walmart?
    In reading this forum, should I purchase bleach, borax, etc...
    Can anyone make any recommendations on any pre testing/service I can do my DE filter and pump tomorrow early to make sure it is ready for filtration? The filter hasn't been used in over a year.
    I'm hoping someone can help me on such short notice. I have done some reading on how to work the pump/filter, but if someone could walk me through what I should do before I plug it in, I would appreciate it. Do I need to still add DE into this used filter?
    Thank you!
    Default Re: New/Used pool start up-newbie-help needed
    We can't check our your pump for you, but we can tell you to get a K-2006 test kit and to use EITHER a Walmart HTH 6-way drops kit (preferred) OR any cheap OTO / phenol red kit.
    Your pool has about 7,400 gallons of water (PF=16), so while you are at Walmart, get 10 gallons of PLAIN 6% household bleach, 2 boxes of 20 Mule Team Borax, and about 4 pounds of stabilizer (cyanuric acid). Each gallon of bleach will add 8 ppm (16 x .5) of free chlorine; each pound of CYA will add 16 ppm of stabilizer; each box of borax will raise your pH exactly "some". Also get EITHER a gallon of muriatic acid (at Lowes, etc.) OR 5 lbs or so of pH Minus (sodium bisulfate)
    Add 1/2 gallon of bleach EACH evening, till you have your pool on a program.
  1. newbie used 2X4 method to start pump, need help on which contacts need cleaning.
    By rnjng in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2013, 01:56 PM
  2. Newbie: Zinc Anodes: Are they needed
    By mnittler in forum In-Ground Pool Construction and Repair
    Last Post: 09-08-2012, 11:04 PM
  3. Newbie question - would we be better off to drain and start over?
    By RockheadedMama in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2011, 10:31 AM
  4. Newbie start-up
    By cschnurr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2006, 12:35 AM
