Hi, One of the things you missed was to not add the cya until the conversion is complete. The chlorine eats the baq and the cya reduces the power of the chlorine. It probably will not hurt you tho. Make sure you keep the chlorine level up to 15 as much as possible as this is what will finish the conversion. Check the water 3 times a day if possible and run the filter 24/7 as long as it doesn't plug. What type of filter do you have?? Good luck Ken
