Re: Cal Hypo
Rickmart
After shocking, the ph rises. Everything else stable.
After shocking the chlorine level also rises and high chlorine can interfere with the pH test and cause it to read high when it is not. This is a chemical interference caused by the phenol red pH indicator being converted into chlorphenol red, which responds to a much lower pH range than phenol red so it seems as if your pH has risen when it has not. If the pH is normal at normal chlorine level and high at shock chlorine level then it is simply this interference and the pH is not really high. Exactly how are you testing your pH? Some pH tests are more susceptible to this problem than others and ti can occur at chlorine levels as low as 3 ppm but most good test kits (such as ones from Taylor and LaMotte) do not exhibit this interference until about 10 ppm chlorine (what is commonly considered "normal" shock level by pool stores).
FWIW, Lo n Slo is just sodium bisulfate or 'dry acid' and there is nothing special about it. Many companies sell dry acid under various names and they are all the same thing, marketing material aside. We actually prefer muriatic acid in the forum because it does not add sulfate to the water but dry acid is certainly acceptable to use unless you have a SWCG.
