Re: Cal Hypo
Without a set of test results to look at, I'm afraid we won't be of much help. If you use smart sticks, which are trichlor, they drive pH down. Then if you shock with cal-hypo, the pH probably rises a little with it. Again...we need to look at your TA, and if you can tell us what range your pH stays in (lowest and highest) then maybe we can give you better info.
