Re: Problems keeping PH in check on indoor covered pool
Alkalinity is now 110 - is was 100 a few weeks ago. Not adding anymore water since getting pool balanced.
PH was 7.4 when balanced, now is off the scale at 8+
We use uv for keeping water sanitary.
forgot to mention that i use muratic acid to get alkalinity correct. I used the aeration method of bringing up the PH once Alkalinity was correct - worked like a charm. I got the pool balanced and kept it balanced for about a week, not a heavy bather loader. then, it started creeping out of range on both PH and Alk. Alk is still ok at 110, but i can't figure out why PH keeps climbing up.
