Results 1 to 10 of 14
Thread: algae problems
    Default Re: algea problems
    Quote Originally Posted by GOINGDEEP View Post
    Pour them all in the skimmer and it will knock the green out in about 12 hours with pump running. It also drops all the dead algae on the floor for easy cleaning.
    While I'm glad that works for you, it's not a reliable method. A week can be long enough to grow a swamp that take MUCH longer to clean up than 12 hours in some pools. NOT recommended.
    Quote Originally Posted by kchamp View Post
    last week
    + I added 2 x 1qt. hth metal control (hydroxyethylidene diphosphonic acid) (HEDP)
    + 4 x hth pool shock 1lb bag (calcium hypochlorite 47.6%) (minimum available chlorine 45%)
    Last night
    + I poured in one gallon jug of shock (sodium hypochlorite 12.5%) available chlorine 12.5%
    + 32oz. of algae control 60 (poly oxyethylene (dimethylimino) ethylene (dimethylimino) ethylene dichloride 60% (POLYQUAT)
    the guy at the pool store told me the green was to much chlorine in it that is why it is green, so I let the chlorine drop back down, still green, so we pull the steps and cleaned the algae off them and left them out. I don`t know if it is algae, black, brown ect. the pool is green like pea soup and you can`t see the bottom. I really just not sure what to do.
    1. Stay away from that bogus pool guy. (Too much chlorine?? Get real!)
    2. Stop using stuff that 'might' help. HEDP is a good thing, but unless you have metals, it does nothing for you.
    3. Stop using chlorine + goop mixtures, like the HTH pool shock (cal hypo should be at least 68% available chlorine - otherwise, leave it on the shelf!)
    4. Polyquat is good stuff . . . but it's not the best thing for cleaning a swamp, at least at first. The large doses of chlorine you need are going to destroy most of it.
    5. Don't use pool store liquid chlorine, unless you are SURE it's fresh. 12.5% bleach, stored at current Chattanooga temps (>100 degrees) will be less than 5% bleach in a week. Use PLAIN 6% household bleach from an air conditioned Walmart!
    I been fighting with algae for a few weeks now and it just keeps getting worse.
    Lots of people 'fight' algae, but never engage in a all-out "you die, or I die" combat. As long as you keep 'fighting' algae, it (and the pool store) wins. Pool stores make $$$$$'s from people who 'fight' algae all summer.
    You have a ~13,000 gallon pool; PF:9. So, 1 gallon of plain household 6% bleach (0.5 lbs Cl2 equiv x 9 = 4.5) will add a little more than 4 ppm of chlorine to your pool. Add SIX gallons (24 ppm) this evening, and every subsequent evening, till the algae turns gray or bluish. Then, add 6 more, and brush the heck out of the pool.
    Run your filter 24/7 during this whole process. Clean it as need.
    And, get a good test kit -- 'guess-strips' help support the whole pool store racket, with their bogus results.
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    Jun 2012
    Vernon, NY
    thanks for the input really appreciate your time, I just went before you posted and bought 4 5gallons 20 gallons total of chlorinating solution that has 12.5 sodium hypochlorite, should I say suppose to have 12.5 so I will have to use it up. do you think pour 10 gallons of that in tonight and maybe 5 gallons in the morning and then the other 5 tomorrow night
    I would add just 3 gallons, or maybe 5. Your 12.5% bleach *may* actually still be 12%, depending on how it has been stored and handled, and you don't want to overdose and bleach your liner out.
    Tomorrow, get an OTO / phenol red test kit. With a vinyl pool, you really don't want to go past 'medium orange', until we have a reliable read on your CYA level. (If the HTH kit is available, it is an OTO kit, at least the chlorine test is)
    Jun 2012
    Vernon, NY
    ok so the green is gone should I keep the bleach to it or let it come back down, it is like a blue whitish cloudy color now. which I new how to post picture
    email them to [email protected] OR post them using the [IMG][/IMG] code, and links to Picasa, Photobucket, Webshots or Flickr.
    The way to tell for sure is to measure your chlorine at night and again in the morning, and make sure you're not still losing chlorine to something in the water. However, if you're sure that all the green is out, and you've thoroughly brushed the pool to make sure there's none hiding in ladder steps, light niches, etc, then you can let the chlorine level come back down--but you need an accurate CYA number to know how far down you can let it drift. If your CYA is actually 90 ppm, then you need to not ever let it get below 5, and you really need to keep it closer to 7-8 ppm. If you let it come down below that, you're going to have algae growing again (see the best guess chlorine chart linked in my sig for more info and the chart).
    The chlorine you put in the pool killed the algae, now it's the filter that's going to remove the dead algae from the pool and clear up the cloudiness. Keep your filter running 24/7, cleaning the filter each time your pressure rises 6-8 psi over your "clean" pressure.
    Jun 2012
    Vernon, NY
    before
    . . . after
    Looks good, but BRUSH the pool, while the chlorine is high. You may stir up hidden piles of algae, that will turn the pool green again, if the chlorine is not high.
    Then filter, filter, filter. Using polyquat, once the chlorine drops into the normal zone (per Best Guess chart) will simultaneously help protect against a recurrence and help filter out the dead algae. However, there's no need to keep using it, once the pool's all cleaned up.
