Closed Thread
Thread: Hi! First time pool owner needs help....!
    Anonymous [GDPR] European in Sweden Guest
    Default Hi! First time pool owner needs help....!
    Hi!
    Have just moved into a new house which has an above ground round 15ft pool (14 m2). With a little help from a friend who has a pool back in UK have started to get the pool ready: so far I have been basically re-pH ing and chloride shocking for the last 4 weeks, with a green pool still the result! Am I just being too cautious with the chlorine etc??
    The pH was ~7.2 yesterday and tonight I have:
    Free Cl- ~10ppm
    Total ppm: (no colour change when tablet added) (Have a gaurdex kit)
    Have been filtering non stop for ages and am on the verge of turning it into a sand pit for the kids!
    Tonight I dumped ~700g chlorine shock in as a last resort!
    Any advice welcome thanks!
    Default Re: Hi! First time pool owner needs help....!
    A chlorine level of 10 ppm and pH of 7.2 is fine.
    We're really limited in the help we can offer folks outside of North America -- most of the products we recommend are unavailable, and all of the test kits are!
    This thread covers some of the issues, and links to a decent testkit that may be available to you:
    http://www.poolforum.com/pf2/showthread.php?15117
    Thanks.
    After dumping a lot more chlorine shock in and leaving the pool filtering overnight the pool is now blue! It is quite cloudy still so have added floccing agent.
    Also I've just pH'd and the Guardex kit started at ~6.8 but then slowly (minutes) turned very alkali - is this interference from the free chlorine?
    Quote Originally Posted by SwedishJim View Post
    Most likely. If the cyanuric acid is low, and the chlorine is high, phenol red is converted to a different indicator, chlorophenol red.
Closed Thread
  1. 1st time pool owner
    By becka'sworld in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-13-2013, 11:09 AM
  2. First time pool owner
    By ZackCB in forum --cleanup--
    Last Post: 06-06-2013, 07:30 PM
  3. First Time Pool Owner, HELP !!!!
    By AngieOlson in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-28-2012, 09:55 PM
  4. New pool owner for the second time...
    By lstinthot in forum Dealing with Algae & Slime
    Last Post: 08-28-2011, 02:44 PM
  5. first time pool owner needs help, please.
    By sneal in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-28-2011, 05:56 PM
