Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 42 of 42
Thread: Algae Problem with Cloudy Water
  1. #41
    Jul 2012
    Oswego, NY
    Default Re: Algae Problem with Cloudy Water
    I'm still seeing small amounts of algae or mustard algae on the bottom in some spots. I have kept the FC at or above 15 for 2 days and not losing more than .5 to 1 a night. How can I still see some algae? All other readings are normal and CYA around 40-50. pH is a little high, I'm assuming from the high FC. I've brushed and vacuumed almost everyday. Water looks good and is clear. Today I thought, that after I vacuum I pull the hose out and it sits there filled with water. Next day or two I vacuum with all the water still in the hose. Emptied it today after I vacuumed. Could this be the problem?
    22'x44' Mountain Lake 24K gal IG pool; SWCG; Ultimate Granular Filtration Millennium sand filter; Waterway 56-Frame Champion with Century Centurion 1.5hp motor pump; 12hrs; Just bought the 6-way from walmart and have the 2006c coming; utility water ; summer: ; winter: ; ; PF:5
  2. #42
    We've seen several cases of VERY chlorine resistant algae in the last month. There are X options:
    1. Hold chlorine levels at 25 - 30 ppm for several days. (No side effects, except increased chlorine use.)
    2. Raise borates to 60 ppm. (All side effects are positive; semi-permanent additive. Reduces algae; does not eliminate it.)
    3. Use sodium bromide (May not be effective; can increase chlorine use for weeks after.)
    4. Use ammonium sulfate or chloride to make monochloramine. (Makes pool unusable for several days; may result in algae rebound after a couple of weeks.)
    5. Use polyquat, after allowing chlorine to drop below 10 ppm. (Slightly increased chlorine consumption; improved water clarity; may not be effective.)
    Please note that the ONLY choice that I know from my own experience will rapidly kill mustard algae is #4, monochloramine. But, I do NOT recommend it -- it makes a mess of your pool, and in my experience, pools on which I used it seemed MORE likely to have algae problems later.
    What I'd recommend is borates. 60 ppm of borates are a good winterizing prep, and will still be there next spring, minus whatever water you drain. Using borates makes the pool MORE, not less, pleasant for swimming. But it's up to you: you can simply raise the chlorine level till the mustard algae dies.
    REGARDLESS of your approach, you need to brush, except with the monochloramine option (#4 - Yellow Out, Green to Clean, Mustard Master, etc.)
    If you want to go with the borax option, I'd suggest ordering this:
    Granular Boric Acid, 55 lb @ Amazon => $117 (2.13/lb)[/INDENT]and this
    Lamote Borate test strips
    Because the boric acid will lower the pH, you'll need to add borax to compensate; both will increase your borate level. More info here: http://www.poolforum.com/pf2/showthread.php?18597
  1. problem with green cloudy water..
    By phillies06 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-11-2012, 10:12 PM
  2. Problem with water being cloudy/murky.
    By TheGoose in forum Pool Equipment & Operations
    Last Post: 08-11-2011, 08:36 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. New Pool w cloudy water and algae problem
    By cokecraze in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-28-2006, 12:46 AM
  5. Another cloudy water problem
    By jwp0077 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2006, 09:49 AM
