Re: Cloudy Water
Hi Melissa,
Your milky water problem is more than likely caused by the addition of calcium to the water, but it also can be caused by a bunch of other stuff. If you could please list a set of current test results, taken with a drop-based kit, (no strips!!) we can better advise you. We also need to know what chemicals exactly you're using in the water. In addition, please take a few seconds to fill out this chart with your pool's info, so we don't waste a lot of your time and posts going back-and-forth trying to get the info we need to make accurate decisions...
Pool Chart Entry Form
Pool Chart Results
Welcome to the forum!
