Thread: 15' round mystic pool above ground
    Default Re: 15' round mystic pool above ground
    Usually, people get pumps that are too big, and filters that are too small. You may have lucked out!
    A heat pump on a 15' pool? The heater will cost more than the pool! If you have the room, a 4'x10' solar panel can be plumbed in pretty easily and should warm your pool more than adequately.
    Smaller pump/ bigger filter: Happy pool owner. Bigger pump/smaller filter: Problems. Horsepower is GREAT in cars, but not so good in pools, especially smaller ones. Your pool is just over 5k gallons. My 16x40 is about 19k gallons and I run a 1 HP pump (OK, it's an IG pump, not an AG, so it's more like a 1.5 AG pump). But I run it at low speed almost constantly, 12 hrs/day and that's like 1/4 to 1/3 hp pump.
    Jul 2012
    New York
    Thanks to all finally got in pool with kids and it seems there might be a sharp rock under bottom of pool what does this mean for my liner..it is 25 gauge..wondering what I should do pool is brand new and was put on top of yard of sand..what options do I have...thanks in advance
    I had the same thing happen underneath one of my liner installs several years ago. I put a double layer of patching over it to give added insurance just in case the rock pushed through the liner. It never did and it did not create any problems. It was still holding just fine when I replaced my pool this year. I think that other liner was purchased in 2006 if I remember correctly.
    May 2012
    Oklahoma
    Having dealt with the Intex salt water thing now for a couple of years, I will not use or get another one when it breaks or stops working. The BBB system here is way to simple and straight forward to do.....especially with the proper test kit. Yes it does make my pool work a little easier, but I still have to test and add a little bleach now and then.....it is NOT worth going and replacing a broke unit now that I know how to maintain a pool.
    Heater....I sure got an earful when I stated I used my little electric heater for my pool a few months back. Problem is, they (as in the forum members) were right. Straight electric heating is expensive to use (but it sure does heat my little pool nicely). May I suggest you look at some sort of solar type heater you could connect to your existing system (even my two little Game solar heaters make a noticeable difference). Now if you want to seriously extend your pool experience, then either the heat pump type or even natural gas/propane heaters could work. As much as you may think you are saving getting a "used" heater off of eBay or Craigslist, please just be very careful what you buy.....there probably was a reason they are dumping their equipment. Corrosion on big components can cost alot of money versus a new, factory waranttee covered heater. A real heater is NOT an inexpensive decision.......just be aware of that.
    Let me just add that adding the solar heaters has allowed me to turn off my electric unit......if you have the room for one, purchased or home built, I would seriously tell you to consider it. The kids don't mind cooler water, my wife and I are the ones who really enjoy the "warm" pool. A good solar system could certain improve your experience in New York....I hate cold pools!!
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
