Re: How to properly chlorinate small 12'x30" intex pool? And few other questions.
Thanks for filling out the chart. The 6-way kit you bought only has enough reagents in it to test CYA 2-3 times. We know there's none in your tap water, so don't waste the reagent testing that. We DO, however, need to know the CYA level in your pool water. And.....if you tell us the ingredients in the granules you already have, you might be able to use them, too. In the meantime, stay with the bleach. A little bit of bleach can do miracles in a pool!
Edit: Need to know CYA in pool, not in fill water!
