Thread: Ring Pool
    Jul 2012
    Tennessee
    Wink Ring Pool
    I purchased this pool two weeks ago. http://www.walmart.com/ip/Summer-Esc...e-Kit/19340402 . I have it level and the chemical tester show ideal for PH and Chlorine. The pool water is not cloudy but we have had two storms during the last week. The first time cleaned up easily. The second storm was worse I worked for 3 hours getting everthing cleaned out. The bottom is clear. The top is clear of anything large but I keep getting "minced" pieces of leaves that are floating between the top and bottom of the pool. I can clean them off when the get to the top but they are tiny. Any suggestions?
    Thanks,
    Betolley
    Default Re: Ring Pool
    I think you're going to have to wait them out, till they float or sink . . . or the storms stop. And, I don't think there's much chance of that last option, this week!
  1. Blow-up ring for Intex Pool solved!
    By drabarni in forum Intex-type Pool Setup & Operations
    Last Post: 06-18-2013, 04:12 PM
  2. Ground By Pool Bottom Ring Wet??
    By poolguy123 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-07-2012, 09:19 PM
  3. Brown oily ring around pool
    By Pamela P. in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2012, 01:22 PM
  4. Scrubbing steps,ring around pool
    By Digger in forum Pool Equipment & Operations
    Last Post: 07-04-2010, 11:19 PM
  5. SW Pool and ring around the tile.
    By Tabby in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-02-2006, 11:25 AM
