Thread: clogged pool filter
    Jul 2012
    North Carolina
    Default clogged pool filter
    I have low filter suction. My pressure gauge is reading 15 - i believe I have suctioned up some leaves and they are caught in the pipes. Can I use a shop vac to remove leaves? If so, what steps are needed to continue with this process?
    Honesdale PA
    Default Re: clogged pool filter
    If you did suck up some leaves then maybe a shop-vac will work to suck them back out. However, the suction side of a pool pump produces way more suction than a shop-vac and they may be really jammed in the pipe. Worth a try though. You can also stick a garden hose in the inlet to the pump basket and pack some rags or something to give a tight fit and see if water pressure can blow the stuff out the skimmer. One reason to always use the skimmer basket.
    Quote Originally Posted by brutuszada View Post
    Filters don't have suction; pumps may though. I assume you mean that there is little suction at the skimmer?
    + Is your flow out of the returns reduced?
    + What is your NORMAL pressure gauge reading?
    It's not too likely that leaves are caught in your pipes. Sticks could be, but those won't be removed with a shop vac.
    Jul 2012
    North Carolina
    Cool Re: clogged pool filter
    wow! Some great responses! I did fill out the PF form as requested and i am going to attempt some of the suggestions. You all are so helpful - thank you SOO much! I will let you know what happens - wish me success!
  1. Clogged filter, cloudy water.
    By timo14 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2013, 12:41 AM
  2. Replies: 0
    Last Post: 12-28-2012, 12:27 AM
  3. Filter sock has clogged supply line
    By Mm_putnam in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 09:05 AM
  4. Pump won’t prime because of clogged filter?
    By Water_man in forum Pool Equipment & Operations
    Last Post: 05-19-2008, 06:13 PM
  5. Sand Filter getting clogged?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2007, 02:38 PM
